Vision T9200 Treadmill Replacement Belt
The first question I ask when a customer calls in with problems with their T9200 is "have you been lubricating the walking belt." Most people don’t realize that their walking belts need to be lubricated at least 2 times a year. When the belt on any treadmill lacks lubrication, the belt dries out, and this creates increased friction. This increased friction wears the belt out prematurely. As belts wear, it can cause a lot of problems with the motor and electronics of the treadmill. There are fibers on the backside of the belt that start to break down over time and with use. This increases the friction between the belt and the surface below the belt, which is called the deck. This extra friction means that the motor has to work harder to maintain the desired speed, and the motor controller has to put out more energy in order for the motor to maintain that speed. The result is that the motor controller starts to get hot and eventually, they fail.
Treadmill Doctor sells a single ply replacement belt and a 2-ply replacement belt for the Vision T9200. The original belt that comes on this treadmill is a 2 ply belt. However, the Treadmill Doctor replacement belt is a thicker more durable belt that holds up much better than the original equipment belt that came with the treadmill. In addition, Treadmill Doctor offers a standard and a professional grade of the 2-ply belt. The standard grade belt comes with a one-year warranty and is less expensive than the Professional grade belt, which comes with a lifetime warranty. The warranties on these belts cover the failure of the belts or in the rare case, if the seam starts to separate.
By replacing the walking belt with a Treadmill Doctor walking belt, you are installing a better quality belt that will give you many years of trouble-free use.
Treadmill Doctor belts come pre-lubricated with our own lubricant. We also include an additional tube of lubricant with every belt shipped, which gives the end-user an approximate 1-year supply. The cost of the belt is also very competitive. At 99.99 it is much better than the original manufacturer'Ă‚?s belt which approximately 2 times as much. When you combine the quality of the belt, the warranty, the price and the lube, I can't think of any reason not to purchase your replacement belts from Treadmill Doctor.
If you have any other questions, or if you feel that you have a problem not listed here, please contact us via e-mail at doc@treadmilldoctor.com
