True M30 Elliptical Review
$2,699.00
How long will the True M30 last?
The True M30 Elliptical is constructed from heavy steel and has a robust 275 lb. fully assembled weight that holds up to a maximum of 300 lbs. workout capacity. It is designed for moderate use in a residential setting and will last years with regularly scheduled maintenance. True covers the M30 with a residential lifetime warranty on the frame, 5 years on parts, and 1 year on labor. Consumers who unplug the M30 after each use will add to the life expectancy of this machine.
The True M30 Elliptical is a previous Best Buy Winner and has been recognized as a top-rate machine more than once over the years. It has an excellent build quality, containing a multitude of quality attributes and would be a welcome addition to any residential workout setting. Consumers among a wide range of fitness levels will benefit from the workouts offered on this machine.
The True M30 Elliptical includes the simple to use Emerge Console containing a retro, orange-colored display screen that shows multiple points of performance data during workout sessions. The console also holds 12 built in workout programs including the Cardio 360™ which enables a choice of lower body, upper body, or total body, low impact workouts by means of the moving handlebars, pedals, and textured side steps. A unique Core Drive® system keeps users centered working and isolating numerous muscles as they trek to their hearts content on the 21” stride length that moves naturally with body exercise motions.
✓generous warranty
✓21” stride length
✓patented heart rate control technology
Xlack of technology
Xshort cord length
Xnot enough features for price
| Color | Silver/Black |
| Power Source | 110V/15A |
| Cord Length | 6' / 1.8 m |
| Drive System | Core Drive® |
| Total Body Workout | Cardio 360™ (Upper Body, Lower Body, Total Body) |
| Resistance Source | Eddy Current Brake |
| Frame Construction | Robotically Welded Heavy-Gauge Steel |
| Maximum Workload | 300 Watts |
| Stride Length | 21" / 53 cm |
| Footpad | Molded Anti-Slip with Textured Pattern |
| Exercise Arms | Protective Dipped Foam |
| Side Step Design | Non-Slip Rubber with Textured Pattern |
| Contact Heart Rate Monitoring | Yes |
| Wireless Heart Rate Monitoring | Polar® Compatible |
| Side Steps | Standard |
| ETL UL 1647 | Yes |
| CSA | Yes |
| EN 957 | Yes |
| Water Bottle Holder | Yes |
| Reading Rack/Tablet Holder | Yes |
| Footprint | 42"L x 30"W x 64"H (107 cm x 76 cm x 162 cm) |
| Active Footprint | 70"L x 30"W x 64"H / 177 cm x 76 cm x 163 cm |
| Q-Factor | 2" / 5 cm |
| Weight | 275 lbs / 125 kg |
| Maximum User Weight | 300 lbs / 136 kg |
| Step-Up Height | 9" / 23 cm |
| Portability | 2 Front Transport Wheels |
| Cardio 360 Virtual Trainer Program | Yes |
Warranty Type: Residential
Frame: Lifetime
Parts: 5 Years
Labor: 1 Year
The True M30 Elliptical was our 3rd place 2021 Best Buy Winner in the $2,000 to $2,999 range and one of the Top 10 ellipticals for 2017. We invite you to see our elliptical reviews to help you narrow your search for your next fitness machine.
In this price range, the True M30 Elliptical contains an excellent mix of quality, engineering, and motion for a wide range of fitness enthusiasts. The lack of technology is telling though, as competitive models offer a connection to the outside world as well as large display screens with interactive technology.
