Best Choice 800W Treadmill Review
$279.00
How long will the Best Choice 800W last?
The Best Choice 800W can be ordered in pink. With a weight of barely 60 lbs., we know this machine is mostly plastic with a wee bit of metal thrown in to make it resemble a treadmill. The weight capacity is 175 lbs. but we are not sure you can even trust that number and stay safe and please do not attempt to go faster than a casual walk – especially if you weigh more than 100 lbs. We don’t know how you would be able to do more than casually walk due to the tiny walking area. We do not believe this machine will last much longer than the 30-day return period.
The Best Choice 800W is a basic folding treadmill that is budget friendly to the cost-conscious beginning user. You could purchase one that is cheap and low-quality, or you could invest your money in something more worthwhile – we recommend looking in the $400 - $600 range at a minimum to get your money’s worth regarding quality and longevity.
The Best Choice 800W is a barely electric folding treadmill that can be bought at bargain prices. You can choose either pink or standard colors and rest assured, no issue will arise moving this machine by yourself out of the way when needed due to the light weight of plastic.
The Best Choice 800W comes with 3 programs that can be terminated with the quick removal of the safety key – not that you will go fast enough to hurt yourself with only an 800-watt motor that has a max speed of 7.5 MPH. The running space is a measly 14” x 39” so if you are larger than a child or take regular strides you are pretty much out of luck with this treadmill. It does have a heart rate sensor in the handlebar, a media shelf, and two cup holders.
  • easy to move
  • compact
    everything else
Material Plastic, Steel
Voltage 110V
Frequency 60Hz
Power 800W
Overall Dimensions 48"L x 25"W x 47.5"H
Folded Dimensions 47.5"L x 24"W x 24"H
Belt Dimensions 39"L x 14"W
Weight Capacity 175 lbs
Weight 59.5 lbs
You might be surprised to learn that there are many different types of treadmills - and then again, you probably are not. The difference between basic models like the Best Choice 800W, versus higher-quality ones can vary drastically in terms of features or specifications while still costing the same amount. It is always smart to research before buying a new piece to enhance your fitness routine and it would be better to initially save a little more and invest in a machine that will last you longer than a few casual workouts.
