Star Trac Trac 8-VS VersaStrider with 15” Embedded Touchscreen Elliptical Review
$10,195.00
How long will the Star Trac Trac 8-VS VersaStrider with 15” Embedded Touchscreen last?
The Star Trac 8-VS VersaStrider is engineered for a commercial atmosphere and weighs a hulking 586 lbs. when fully assembled. Additionally, the VersaStrider holds a massive 400 lbs. of workout capacity and will last for over a decade with proper care and maintenance. All Star Trac 8 series carry a commercial warranty that covers 10 years on the frame, 2 years on parts, and 1 year on labor with the residential warranty covering 10 years on the frame and parts with 3 years on labor.
For a mighty workout machine, the Star Trac 8-VS VersaStrider is simple to use with an easy to mount platform for safely entering and exiting workout sessions. Consumers can hop on and start trekking their way to glory at their own pace by means of technology that works with individualized strides for a natural walking motion that follows the lead of each user. It comes with 3 different console options that range from a simple LCD screen to the 15” touchscreen with a plethora of additional options depending on which console is chosen at purchase.
The top choice console for the Star Trac 8-VS VersaStrider is the 15” Embedded Touchscreen that holds 20+ built in workout programs and is Wi-Fi enabled, meaning users can surf the web or watch their shows during exercise periods. Leaderboard activity helps motivate users to give their all while data is transmitted to 3rd party apps along with Apple and Samsung watches for those tracking performance stats during and after workout sessions. The VersaStrider has a an adjustable 10” to 32” stride length, meaning consumers of all sizes and shapes will greatly benefit from the elliptical exercise motion attained using this machine. Moving handlebars converge to form a natural path motion and assist with toning upper extremities during total body workouts. Adjusting resistance level is easier with controls located directly in the moving handlebars so no need to release the hand grips during exercise fun.
  • 15” touchscreen
  • 10” to 32” adjustable stride
  • resistance buttons in moving handlebars
    expensive
    warranty
Step Up Height 11" (28 cm)
Stride Type Dynamic Variable
Stride Length 10" to 32"
Heart Rate Measurement System Telemetry and Contact HR( Bluetooth with Embedded Display)
Movement Arms Converging Movement Arms with Multiple Hand Grip Options
Controls Integrated into Movement Arms
Display Choose from LCD, 10" or 15" OpenHub Display Options
Accessories Multiple Bottle and Accessory Holders, LCD and 10" Displays Pre-Wired for 8 Series PVS Entertainment, 800/900MHz Receivers, and Tablet Holder
Max User Weight 400 lb (181kg)
Drive Front drive
Resistance System Alternator
Electrical Requirements LED is Self-Generating; PVS Option Requires 12V/5 Amp Power Supply
Start Up Watts 20
Additional Features Rear Courtesy Step
Frame Material Powder Coated Steel Frame
Customizable Paint Color Options Approval Required
Standard Color Options Star Trac Silver
Dimensions 89"L x 35"W x 69"H (226 cm x 89 cm x 175 cm)
Weight 586 lbs (266kg)
Shipping Dimensions 89" x 35" x 49" (226 cm x 90 cm x 125 cm)
Shipping Weight 694 lbs (315kg)
PVS 10/8/4 Series
Display Type 15.6" HD LED
Resolution 1366 x 768
Tuner Options 1) ATSC/NTSC/QAM 2) PAL/DVB-T/DVB-C
Digital and Analog Support Yes
Signal Inputs Coax, HDMI
Input RFSignal Range -70 dBm(Min) ~ to 10 dBm(Max)
Close Caption Yes
Headphone Jack 3.5 mm Integrated on PVS face
We invite you to see our elliptical reviews to help you narrow your search for your next fitness machine.
For consumers looking to spend a large sum of money on a premium workout machine, the Star Trac 8-VS VersaStrider is the perfect choice and a worthwhile investment for any commercial setting. This machine will last for many years in a climate-controlled atmosphere with proper care despite the obviously substandard warranty coverage offered by the parent company.
