LifeSpan TR2000e Electric Folding Treadmill
$1,499.00
How long will the Lifespan TR2000e last?
The Lifespan TR2000e treadmill has an assembled weight of 211 lbs. and is made from a strong mixture of steel and plastic that can hold users up to 300 lbs. weight capacity. Lifespan has backed the TR2000e with a lifetime frame and motor warranty, 5 years parts, and a 1-year labor warranty, and it has an electronic folding system and 6 wheels to conveniently move when space options are limited. Light to moderate users should get a multitude of workout opportunities over several years with proper care and maintenance.
The Lifespan TR2000e treadmill is a marvel of safety with the built-in stop sensor that recognizes movement while the frame is lowering and stops it from injuring children and pets. It has been designed with several quality features that are backed by warranties from a reputable company. The TR2000e is simplistic in nature, quite easy to use, and can get you moving and exercising with a quick push of a button. Though its motor is lower powered than others in this price range, the TR2000e remains competitive with quality attributes that keep it on equal or better footing than other models priced under $1500.
The Lifespan TR2000e treadmill is quite an offering in the treadmill industry, built with both functionality and a path to connectivity with a Bluetooth device. It has a 20” x 56” running surface that is best for shorter walkers and joggers, while offering a 15% incline which adds intensity to every lower body workout. A maximum speed of 11 MPH is available but serious runners are not recommended for this treadmill even though it can handle a sprint or two from a shorter individual. Users can remain stress-free as 8 independent compression shocks keeps painful impacts on knees and joints to a minimum.
There is a 6” blue backlit screen on the Lifespan TR2000e treadmill that is both easy to read and soothing to the eyes, while an audio jack lets you plug in and enjoy music through the integrated speakers. Bluetooth capabilities allow the sharing of data with the Lifespan app along with 21 built programs to keep cardio workouts at premium levels. A heart rate monitor can be found in the ergonomic grip handles and 2 water bottles adorn the fan-less console.
  • warranty
  • budget friendly
  • some technological features
    small screen
    lower powered motor
    no fan
Belt Size 56"L x 20"W
Drive Motor 2.5 HP Continuous Duty DC
Belt Type 2-Ply
Incline Motor 800 lbs Maximum Lift
Rollers 2.5" Front, 2" Rear
Speed Range 0.5 to 11 mph
Incline 15 Levels
Deck Suspension 8 Independent Compression Shocks
Deck 3/4" Phenolic
Folding System eFold™ Electric Folding System
Transport 4 Front-Mounted and 2 Rear-Mounted Wheels for Convenient, All-Direction Mobility and Easy Storage
Side Rails: Non-Slip Plastic Side Rails Provide Balance and Safety while Starting and Stopping the Treadmill Belt
Dimensions: Unfolded: 71"L x 33"W x 56"H. Folded 50"L x 33"W x 56"H
Step-Up Height 8"
Weight 211 lbs
Max. User Weight 300 lbs
Power Requirements Requires a 115V NEMA 5-15 Non GFI Circuit
Frame: Lifetime
Motor: Lifetime
Parts: 5 Years
Labor: 1 Year
The Lifespan TR2000e treadmill is a budget friendly compact treadmill with many quality attributes that make is attractive to a plethora of fitness enthusiasts. It is designed with durability in mind for those of the smaller persuasion and has generous warranties that can be extended through a third-party vendor. It is quite a deal for less than $1500 and remains competitive despite the many treadmills that are available on the market today.
