Landice Model 8700 Walking Belt
This is a perfect replacement belt for the Landice 8700 treadmill. This walking belt is composed of industry-grade polypropylene materials, has a 2-ply construction, and a backing made of polyester blended material to render durability. Optimized for smooth operation, this walking belt enhances the performance of the treadmill.
Compatibility
This replacement belt is specifically designed to fit the Landice 8700 treadmill. Please verify your model number and purchase the correct replacement belt for your specific treadmill model for a perfect fit and smooth operation.
Working
Powered by an electric motor, the walking belt moves around the deck from front to rear. The running surface enables you to exercise, whether you choose to do light mobility training or an intense, power-packed run.
Uses
The Landice Model 8700 walking belt is used for:
  • Aerobic workouts: Walking or running on the treadmill makes your lungs work harder and your heart pump faster, ensuring good cardiovascular health.
  • Maintaining Healthy Weight: Regular exercise on the treadmill helps you with calorie burn and weight management.
  • Rehabilitation: People undergoing physical therapy can walk on the treadmill belt and do light mobility exercises to support their recovery.
  • Convenience: Whether it is raining or sunny weather outside. You can get your steps in by walking on the treadmill.
  • Visible Wear: The walking belt wears out due to friction and regular use with time. When you see cracks, holes, and uneven wear on your treadmill belt, replace it.
  • Decreased Performance: A worn-out walking belt functions slowly despite more speed on the dashboard. If the efficiency doesn’t improve despite lubrication, it is time to replace it.
  • Fraying Edges: When the belt starts to fray, it indicates the belt has run its course and needs to be replaced.
  • Excessive weight: Excessive force and exceeding the treadmill weight limit over a long period can accelerate belt wear due to increased friction.
Get your Landice Model 8700 replacement belt from Treadmill Doctor and have your treadmill functioning like new, once again.
Weight
‎8.0 Lbs
Model
8700
Type
Treadmill Walking Belt
MPN
N/A
Activity
Running/Jogging/Walking
Landice
Lifetime
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Model
8700
Type
MPN
N/A
Activity
Landice
