Landice L10 Replacement Walking Belt
Landice L10 Replacement Walking Belt image 1
Landice L10 Replacement Walking Belt image 2
Landice L10 Replacement Walking Belt image 3
Landice L10 Replacement Walking Belt image 4
Landice L10 Replacement Walking Belt image 5
Landice L10 Replacement Walking Belt image 6
1 / 6
This is a Treadmill Doctor Replacement Landice L10 Replacement Walking Belt.
The Landice L10 Walking Belt is a high-quality replacement belt made of durable materials. It provides smooth and reliable performance during workouts.
Moreover, it is pre-lubricated to minimize friction and ensure a quiet operation.
This Treadmill Doctor walking belt comes with a one-year warranty that covers defects in materials and workmanship in commercial settings.
Additionally, we boast a lifetime warranty for residential users.
Compatibility
This pliable walking belt is exclusively compatible with the Landice L10 treadmill. It is not designed to fit other treadmill brands or models.
Working
The walking belt is the essential component that moves underneath your feet as you walk or run on the treadmill. A motor drives it and works with the treadmill's deck and rollers. When you turn on the treadmill, the belt begins to rotate, allowing you to walk or run.
Uses
The Landice Model L10 Walking Belt is used for various fitness activities, including walking, running, jogging, interval, and incline training.
Over time, the walking belt on a treadmill can wear out due to many factors.
  • Improper maintenance: Failing to clean or lubricate the belt regularly can lead to premature damage.
  • Natural wear and tear: Even with proper care, belts can naturally wear out over time.
  • Overloading the Treadmill: Exceeding the treadmill's weight capacity can strain the belt excessively.
If you notice any or more of the following signs, it may indicate that your Landice walking belt needs to be replaced.
Price for all 3 items $223.97
More from Landice
Landice Slip Coat Treadmill Lubricant 1 oz-img
Part number: 16728
Landice L7 Walking Belt Part Number 73050-img
Part number: 73050
Landice L8 Walking Belt Part Number 70292-img
Part number: 70292
Landice Model 8700 Walking Belt-img
Part number: 70046
Landice Model L7 Walking Belt Part Number 70468-img
Part number: 70468
Vision T-7000 Reed Switch 001961-D2 Part Number 001961-D2-img
Part number: 001961-D2
Vision T-7400 Reed Switch 001961-D2 Part Number 001961-D2-img
Bowflex Saftey Key KK-6178-T
Part number: KK-6178-T
Part number: 001160-A
