AFG Sport 3.5AT Treadmill Review
$599.00
How long will the AFG Sport 3.5AT last?
Expecting the 3.5AT to last longer than a few years is like expecting Ellen not to dance. This treadmill is so affordable because it is not the best quality. Even still, Johnson has found a way to build a somewhat strong build and have even added a decent warranty. Both show Johnson's ability to give a decent standard of quality and stand behind even their most basic products. Thus, if you enjoy walking on a weekly basis, then you will more than likely be able to see a solid few months out of the 3.5AT. We always recommend taking the best care possible of your treadmill in order to reap the most quality out of the machine. So, please keep in mind that leaving your treadmill plugged in in the garage will surely shorten its life.
Just as there is a market for cheap, dollar spatulas that last a few weeks, there is also a market for cheap treadmills. While we like the AFG company reputation and their attempt to make an affordable treadmill, we would not recommend the 3.5AT for even a moderate user. With that said, this is one of the better lower-end treadmills on the market with a slightly better build and warranty.
To start, we would like to stress just how much we do not recommend buying such a cheap machine. When it comes to treadmills, you usually need to spend upwards of $1,000-$1,500 to get any sort of long-lasting decent quality. If you are hoping to exercise daily or train for some sort of walk or run, then your money would be better spent on a machine that has better quality. Generally speaking, the higher the price tag, the indication of more value. The important aspect of finding a treadmill most suitable for you is to decide if the manufacture’s view of value and quality fall in line with yours. If you do, then you will more than likely find their particular price tag most agreeable.
Now, there are a few good qualities in the 3.5AT. This treadmill is affordable which may make it a good beginner treadmill. If you have never owned a treadmill and are wondering if it will benefit your lifestyle, then a cheaper, decent quality treadmill such as this one may be a good decision. But if you know you want a treadmill and are willing to invest a decent chunk of change, then you will be better off with a more expensive machine that is built with more quality. The reason why we value the 3.5AT as a decent starter treadmill is mainly because of its build and the company that makes it. Johnson is AFG's parent company. They have built a reliable reputation over the years for their ability to build quality machines and provide good service. Subsequently, even though the 3.5AT is AFG's most basic treadmill, it still has a higher level of quality than other companies' treadmills thanks to the Johnson name. Additionally, most companies only give a ninety-day warranty to treadmills that are under $800 dollars. AFG has backed the 3.5AT with a lifetime frame and motor warranty as well as a one-year-parts and labor warranty. This kind of warranty on a lower-end treadmill adds a decent amount of value.
Still, we cannot ignore the negative aspects of the 3.5AT. This treadmill only comes with nine built-in workouts which does not add much value. Outside of the technology, you receive standard features and not much else. The 3.5AT can incline up to ten percent and reach ten miles per hour with a standard twenty-inch walking area. Though AFG has not cut as many corners as other brands, this minimum number of features and quality are not likely to last you more than a few months. But, hopefully, you do not have the highest expectations for a six-hundred-dollar treadmill.
  • Sleek Design
  • Okay Build
  • Decent Warranty
  • Affordable Beginner Treadmill
  • Good Company
    Limited Technology
    Not a Reliable Machine
Number of Programs 9
Heart Rate Sensor and Type Contact Grips
Speed Range 0.5 - 10
Incline/Decline Range 0 - 10%
Weight Capacity 300 Lbs
Footprint 70 x 33 x 55
Folds Yes
Weight of Unit 196 Lbs
Warranty Frame Lifetime Motor Lifetime Parts 1Yr Labor 1Yr
Horsepower 3.5
Belt Size 20 x 55
Our other reviews have said that the AFG 3.5AT is a swing and a miss. While we have recognized the affordability of this treadmill, we have also noted that this machine is probably only suitable for elderly people who don't weigh much and don't walk much.
We would not recommend the 3.5AT for a moderate or a serious user. With that said, you could do much worse. Comparatively, the 3.5AT is a slightly above average treadmill with a decent quality build and good company backing among the other lower-end treadmills. Thus, while we do not foresee the 3.5AT lasting more than a few months, we would recommend this treadmill for a very light user or someone looking to test out owning a treadmill.
Customer Reviews
41.3 out of 5 stars
5 Star
0%
4 Star
0%
3 Star
0%
2 Star
25%
1 Star
75%
Gk- Do not buy this treadmill Feb 27, 2020
Do not buy the afg treadmill. It is not even 2 years old and we had to replace the control board and belt has worn out for the second time, has holes in it even though it was lubed regularly. It cost $200 for parts.
Chris - Don’t do itApr 23, 2020
Should have read more into reviews. Works good, when it works. Just replaced motor last week. Now they say it needs a new circuit board. When you add in “travel costs” for repairs, we are closing in on paying more for repairs than what we paid. Don’t do it!
C Bautista- Only had it for 2 years and broke!Feb 13, 2021
I was so happy to get a treadmill at home and when I stumbled upon this at Dicks Sporting goods for $500 (It was on sale, the usual price is $600) I normally do not go on it every day, but occasionally use it. After two years, the switchboard light stopped showing, and at first, it was okay because I only really needed to run a few minutes on it but then it started really being messed up by stopping all of a sudden and then get really fast without touching any buttons. I had to stop using it or it can literally cause an accident. DONT BUY plain and simple. Amazon sells better ones!
Toni- Don't Buy-Piece of Junk Mar 03, 2021
My bad for leaving it plugged in inside the garage, but it was hardly ever used and after a couple of years sitting dormant, I went to use it and the buttons won't control anything so it doesn't startup. Stays stuck on "Select Target". Went through all the troubleshooting with tech support and never got anywhere. Hubs diagnosed it and likely needs a new motherboard to the tune of nearly $300, so it's being donated to Goodwill. Maybe someone there has the skills to fix it up. I know it's cheap (@$600), but you'd expect with very light and infrequent use, that it would last a bit longer.
