Xterra TR 6.8 Treadmill Walking Belt item H0613120
Engineered to meet the demands of regular use, Xterra TR 6.8 treadmill belt has been crafted from durable polypropylene materials, 2-ply construction with a polyester-blended backing. This provides excellent traction and cushioning, while ensuring optimal performance and longevity.
Compatibility
This walking belt Part Number H0613120 is specifically designed for the Xterra TR 6.8 treadmill. It is a direct replacement for the original belt, ensuring a perfect fit and easy installation.
Do remember to ensure compatibility with your treadmill model to avoid any fitment issues or performance degradation.
Working
The walking belt is a crucial component of a treadmill. It provides the surface on which you walk or run. The belt is driven by a motor and moves at a controlled speed, simulating outdoor walking or running conditions.
Uses
  • Improved Performance: A new belt can significantly enhance your treadmill's performance, providing a smoother and more efficient workout.
  • Reduced Impact: The cushioning and support offered by a new belt can reduce the impact on your joints, especially during high-intensity workouts.
  • Increased Treadmill Lifespan: Regular replacement of the walking belt helps to maintain your treadmill's overall performance and prolong its lifespan.
  • Wear and Tear: Over time, the belt can experience wear and tear, leading to reduced traction and performance.
  • Belt Slipping: If the belt slides when used, it may be a sign that it is stretched or worn out and needs to be changed.
  • Improper maintenance: Failing to clean or lubricate the belt regularly can lead to premature damage.
  • Natural wear and tear: Even with proper care, belts can naturally wear out over time.
  • Overloading the Treadmill: Exceeding the treadmill's weight capacity can strain the belt excessively.
To extend the Life of a walking belt, clean the belt regularly to remove dirt, debris and sweat. Also, lubricate the belt as recommended by the manufacturer to reduce friction and wear.
Don't let a worn-out belt hinder your fitness goals. Upgrade your Xterra TR 6.8 treadmill with a new walking belt today and experience the difference.
Weight
‎8.0 Lbs
Model
TR 6.8
Type
MPN
H0613120
Activity
Walking/Jogging/Running
Xterra
Lifetime
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Model
TR 6.8
Type
MPN
H0613120
Activity
Xterra
