Vision Fitness T9250 TM43 Treadmill Walking Belt Part Number 1000210085
The Vision Fitness T9250 TM43 Treadmill Walking Belt is a high-quality component made from quality polypropylene materials. As leaders in the fitness industry, we offer 2 ply construction with a backing made of polyester blended material. This helps increase longevity and durability of our belts.
Compatibility
This walking belt is designed for the Vision Fitness T9250 S/N: TM43 treadmill.
Due to differences in belt size, shape, or motor specifications, it may not be compatible with other models.
Working
When you turn on the treadmill, the motor drives the walking belt. As the belt rotates, it creates a moving surface for you to walk or run on. The belt's speed & tension can be adjusted as needed.
Uses
The Vision Fitness T9250 TM43 Treadmill Walking Belt is primarily used for walking, jogging, running, and even in physical therapy to help individuals recover from injuries or conditions.
Several factors can contribute to the wear and tear of a treadmill walking belt, necessitating replacement:
  • Excessive use: Frequent or intense workouts can accelerate belt wear.
  • Improper maintenance: Failing to clean or lubricate the belt regularly can lead to premature damage.
  • Misalignment: If the belt is not aligned correctly with the deck, it can experience uneven wear and tear.
Weight
‎8.0 Lbs
Model
T9250 S/N: TM43
Type
MPN
1000210085
Activity
Walking, Running, Jogging
Vision Fitness
Lifetime
Walk Belt Warranty LIFETIME - $129.99 Read More Walk Belt Warranty 1 YEAR - $119.99 Read More
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Model
T9250 S/N: TM43
Type
MPN
1000210085
Activity
Vision Fitness
