Spirit 225 Wide Walking Belt
The Spirit 225 Wide Walking Belt is a replacement belt for the Spirit 225 treadmill that offers a robust and reliable surface for walking, jogging and Running. This wide belt treadmill accessory is made from quality polypropylene materials, 2 ply construction with the backing made of polyester blended material to ensure durability and longevity.
Spirit 225 treadmill walking belt provides ample space for comfortable movement, reducing the risk of slipping or missteps during your workout.
Compatibility
The Spirit 225 Wide Walking Belt is specifically designed to fit the Spirit 225 treadmill model. This compatibility ensures that users can easily replace their existing belts without worrying about fit issues. A proper fit is crucial for maintaining the treadmill's performance and prolonging its lifespan.
Working
This walking belt operates smoothly and provides a consistent surface that supports various walking speeds. Its design minimizes friction against the treadmill deck, promoting efficient energy transfer and prolonging the lifespan of both the belt and the machine.
For tips on how to keep your treadmill in top shape, including how to lube a treadmill, visit our resource page.
Uses
  • Ideal for walking, jogging and running.
  • Provides a spacious surface for users of all sizes.
  • Reduces wear on internal components that may lead to treadmill repair.
  • Easy to install, allowing for quick replacements when necessary
Problems That Lead to the Replacement of the Belt
  • Excessive Wear: Over time, belts can fray or wear out due to regular use.
  • Cracking or Splitting: Exposure to heat and moisture can cause deterioration.
  • Slipping: If the belt has stretched or become misaligned, it may slip during use.
  • Noise: Unusual sounds during operation can indicate that the belt is not functioning properly or needs treadmill lubricant.
Weight
‎8.0 Lbs
Model
Spirit 225
Type
Treadmill Walking Belt
MPN
N/A
Activity
Walking, Light Jogging
Spirit Fitness
Lifetime
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Model
Spirit 225
Type
MPN
N/A
Activity
Spirit Fitness
