Sole F80 (Serial Number 580881) Walking Belt 20 x 116.6 Part Number 000951 V1
The Sole F80 (Serial Number 580881) Walking Belt is a high-quality replacement part designed for the Sole F80 (Serial Number 580881) treadmill model. Crafted from durable materials, this belt ensures smooth and consistent performance during your workouts. It's designed to provide a comfortable and stable running or walking surface, making it a valuable addition to your home gym equipment.
Our walking belts are made from quality polypropylene materials, 2-ply construction with the backing made of polyester blended material. You may opt for the Lifetime warranty when in a residential setting and the 1-year warranty in a commercial setting.
Compatibility
This walking belt is specifically designed to fit the Sole F80 treadmill model. Verifying compatibility with the first 6 digits of the serial number 580881 before purchasing is essential to ensure a proper fit and optimal performance.
Working
The walking belt acts as a moving surface on your treadmill. As the belt rotates, it provides a simulated walking or running experience. The belt's thickness and material composition are crucial in determining your workout's overall comfort and durability.
Uses
The Sole F80 Walking Belt is primarily used for walking and running workouts on the Sole F80 treadmill.
Problems Leading to Replacements
Over time, walking belts can experience wear and tear due to factors such as:
  • Excessive use: Frequent or intense workouts can accelerate belt degradation.
  • Improper maintenance: Neglecting regular cleaning and treadmill lubricant can lead to premature wear.
  • Misalignment: Incorrect belt alignment can cause uneven wear and potential damage.
  • Foreign objects: Debris or small objects trapped beneath the belt can cause damage.
If you notice any of these issues, you can read our how to lube a treadmill guide page, it's recommended that the sole f80 treadmill walking belt replacement is done to ensure optimal performance and safety.
Weight
‎8.0 Lbs
Model
F80 (580881)
Type
Treadmill Walking Belt
MPN
000951 V1
Activity
Running/Jogging/Walking
Sole
Lifetime
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Model
F80 (580881)
Type
MPN
000951 V1
Activity
Sole
