Replace the Running Deck on a Smooth 5.65i
Step 1
With a Phillips Screwdriver, remove 5 screws in order to remove the motor cover.
Step 2
remove these screws to remove the foot covers. Step3
Step 3
Remove these screws in order to remove the end caps
Step 4
Remove the middle strip of the side rail.
Step 5
remove these screws in order to remove the side rail.
Step 6
Use an allen wrench to loosen the rear roller. Then remove the deck bolts.
Step 7
Slide the deck out and then reverse the process to install new deck.
