Proform CADENCE COMPACT 500 Treadmill Walking Belt Part Number 421905 For Model Number PFTL396210
This Treadmill Doctor replacement walking belt is designed specifically for the Proform Cadence Compact 500 treadmill model number PFTL396210. It is made from quality polypropylene materials, with a 2-ply construction and a backing made of polyester-blended material.
Compatibility
This walking belt is precisely engineered for compatibility with the Proform Cadence Compact 500 treadmill, model PFTL396210. This replacement provides a perfect fit and seamless integration with your specific treadmill model.
Using a belt designed for a different model can lead to improper fit, premature wear, and potential damage to the treadmill's motor and other components.
Working
The walking belt is a crucial component of your treadmill, providing the surface you walk or run on. It's driven by the motor and rollers.
Uses
  • Improved Safety: A worn belt can slip or snag, creating a safety hazard. A new belt provides a stable and secure running surface, reducing the risk of falls or injuries.
  • Reduced Wear and Tear: Replacing a worn belt prevents further damage to the treadmill's motor and other components, saving you costly repairs down the line.
  • Enhanced Performance: A new belt ensures consistent speed and a more natural running feel. This leads to a more effective and satisfying workout experience.
  • Visible Wear and Tear: Cracks, fraying edges, or a worn surface indicate it's time for a replacement.
  • Slipping or Stuttering: If the belt slips or stutters during use, it's a sign of wear or stretching.
  • Excessive Noise: A worn belt can create excessive noise during operation.
  • Uneven Running Surface: If the belt is uneven or has bumps, it can create an uncomfortable and potentially unsafe running surface.
Don't let a worn treadmill belt hinder your workouts. Restore your Proform Cadence Compact 500 to peak performance with this high-quality replacement walking belt from Treadmill Doctor. Order yours today!
Weight
8.0 Lbs
Model
Cadence Compact 500 PFTL396210
Type
MPN
421905
Activity
Walking/Jogging/Running
Proform
Lifetime
Walk Belt Warranty LIFETIME - $99.99 Read More Walk Belt Warranty 1 YEAR - $89.99 Read More
Lifetime
Compatibility
Working
Uses
Specifications
Weight
8.0 Lbs
Model
Type
MPN
421905
Activity
Proform
