NordicTrack t 6.5 s Treadmill ntl1791514 Walking Belt 392489
This is a replacement Walking Belt for the NordicTrack t 6.5 s Treadmill ntl1791514 Walking Belt 392489. When it comes to replacement walking belts Treadmill Doctor has been a leader in the fitness industry. Our walking belts are made from quality polypropylene materials, 2 ply construction with the backing made of polyester blended material. A warranty for our walking belts is offered depending on your setting you may want to opt for the Lifetime warranty when in a residential setting and the 1-year warranty in a commercial setting.
Compatibility:
This walking belt is specifically designed for the NordicTrack T 6.5 S treadmill model number NTL1791514. It is crucial to verify the compatibility of the belt with your treadmill's model number to ensure a proper fit and function.
Working:
The treadmill belt works by rotating on two rollers powered by the treadmill's motor. As the belt rotates, it creates a running surface that allows the user to walk or run. The belt is tensioned to ensure that it does not slip or slide while in use.
Uses:
The NordicTrack t 6.5 s Walking Belt is used for walking, running, and jogging.
Problems that Lead to Replacement:
  • A worn or damaged treadmill belt can be a safety hazard. We offer treadmill repair and replacement services.
  • Uneven wear on your treadmill belt might signal alignment issues or a lack of maintenance.
  • Regular lubrication of your treadmill belt with specialized treadmill lubricant can help prevent wear and tear.
  • Unusual noises from your treadmill could indicate the belt rubbing against other parts. This problem needs immediate attention.
  • A frayed or damaged treadmill belt is a serious safety concern. Thus, Nordictrack t 6.5 s treadmill belt replacement becomes must.
  • Our guide provides detailed instructions on how to lube a treadmill belt properly.
Weight
‎8.0 Lbs
Dimensions
N/A
Model
T 6.5 S
Type
Treadmill Walking Belt
MPN
392489
Activity
Running/Jogging/Walking
NordicTrack
We have two warranty periods for 1 year or a lifetime.
Walk Belt Warranty 1 YEAR - $114.99
RESIDENTIAL USE:
This product comes with Treadmill Doctor's leading 1-year warranty against any defects in materials or workmanship.
REQUIREMENTS FOR VALID WARRANTY: To maintain the warranty, the underside of the walking belt must be lubricated once every year using World Famous Lube.
COMMERCIAL USE:
The walking belt has a 30-day warranty for commercial applications.
Walk Belt Warranty LIFETIME - $124.99
RESIDENTIAL USE:
This product comes with Treadmill Doctor's industry-leading lifetime warranty against any defect in materials or workmanship.
REQUIREMENTS FOR VALID WARRANTY: Lubricate the underside of the walking belt once every year with World Famous Lube.
COMMERCIAL USE:
This product comes with a 1-year warrant for commercial applications.
REQUIREMENTS FOR VALID WARRANTY: Lubricate the underside of the walking belt once every three (3) months with World Famous Lube.
Lifetime
$109.99
Walk Belt Warranty LIFETIME - $109.99 Read More Walk Belt Warranty 1 YEAR - $99.99 Read More
Lifetime
Compatibility:
Working:
Uses:
About This Item
Weight
‎8.0 Lbs
Dimensions
N/A
Model
T 6.5 S
Type
MPN
392489
Activity
NordicTrack
Warranty Details
RESIDENTIAL USE:
COMMERCIAL USE:
RESIDENTIAL USE:
COMMERCIAL USE:
