Lifespan Tekk 1 Treadmill Walking Belt
Crafted with 2-ply construction, polypropylene material and a polyester-blended backing, this walking belt offers exceptional durability and longevity. It is durable, long-lasting and delivers exceptional performance. Upgrade your worn-out Lifespan Tekk 1 Treadmill Walking Belt with this premium replacement belt.
Compatibility
This replacement belt is exclusively designed for the LifeSpan Tekk 1 Treadmill. Before buying, check the compatibility of your treadmill with the belt for smooth installation and operation.
Working
A treadmill belt is a surface that you walk on. It operates through a system of motorized rollers and provides the user with a simulated walking or running experience. The motor rotates these rollers, propelling the belt backward and enabling you to move forward.
Uses
  • Doing Cardio - It is used to run to improve heart rate for cardiovascular benefits.
  • Long-distance walking/running - Athletes preparing for marathons use running belts to build endurance for longer distances.
  • Smooth Treadmill Operation - Replacing the worn-out belt prevents treadmill damage, maintains optimal function & significantly increases its lifespan.
  • Severe Cracking & Splitting - When deep cracks or splits appear in the belt, it affects the treadmill function and the quality of your workouts and demands belt replacement.
  • Belt Slippage - Frequent belt slippage, even at low speeds and after adjusting the belt tension right multiple times, indicates loss of traction and a worn-out belt.
  • Noise during Operation - If you witness increased noise levels during function, it can be because of its natural wear and tear.
Meet your fitness goals and don’t let a worn-out Lifespan Tekk 1 Treadmill Walking Belt stop you! Order a replacement belt from Treadmill Doctor TODAY!
Weight
8.0 Lbs
Model
Tekk 1
Type
MPN
N/A
Activity
Walking/Jogging/Running
LifeSpan
Lifetime
Walk Belt Warranty LIFETIME - $99.99 Read More Walk Belt Warranty 1 YEAR - $89.99 Read More
Lifetime
Compatibility
Working
Uses
Product Specifications
Weight
8.0 Lbs
Model
Tekk 1
Type
MPN
N/A
Activity
LifeSpan
