LifeSpan Fitness 100% Silicone Treadmill Belt Lubricant
Discover the ultimate 100% Silicone Lubricant, perfect for all treadmill belts—whether you have a home model, a compact folding treadmill, or a commercial-grade machine. With an EZ-Spray bottle, applying Life Span's treadmill lubricant oil is a breeze, ensuring precise application every time.
LifeSpan Fitness 100% Silicone Treadmill Belt Lubricant is a high-quality lubricant specifically designed for treadmills. Made from pure silicone, it is free of harmful chemicals, ensuring safety for both users and machines. An 8 oz bottle is sufficient for eight applications! This odor-free Silicone Slipcoat lube is a MUST BUY!
Key Features
100% Silicone: Our lubricant is made from pure silicone, offering unmatched quality and effectiveness in reducing friction between your treadmill belt and deck. No more worrying about excess wear and tear on your machine.
Easy Application: Applying the lubricant is a breeze with the included applicator—no spills, no fuss! Enjoy smooth, effortless maintenance that keeps everything running smoothly and efficiently without any hassle.
Reduces Friction: Our lubricant reduces friction and heat, safeguarding your treadmill's belt, motor, and electronic parts. This protection not only extends their lifespan but also guarantees a smooth and reliable performance every time you exercise.
Compatibility: LifeSpan Fitness 100% Silicone Treadmill Belt Lubricant is perfect for all treadmill types, from sleek home models to heavy-duty commercial machines, ensuring smooth and efficient performance for your workouts.
Quantity: Each bottle offers excellent lubrication for various uses, so you can maintain your treadmill's peak performance without the hassle of constant reorders. Keep your equipment in top shape effortlessly!
Usage Instructions
  1. Power Down: Start by turning off and unplugging your treadmill for safety.
  2. Locate the Walking Belt: Lift the treadmill walking belt slightly to expose the deck.
  3. Apply the Lubricant: Spray a small amount of lubricant along the underside of the belt.
  4. Spread Evenly: Gently spread the lubricant using the applicator to ensure an even distribution.
  5. Power Up: Plug in your treadmill and turn it on at a slow speed without a user for 60 seconds and then by walking at a slow speed for 60 seconds to evenly distribute the lubricant.
  6. Repeat Lubrication after Inspection: Reach your hand under the belt and if you can't feel a bit of moisture under the walking belt, it is time to reapply the 100% silicone lube. So repeat the process explained above.
Enhance your treadmill experience by maximizing motor lifespan, minimizing noise, and cutting down on maintenance. Choose Life Span's specialized treadmill belt lubricant for an efficient and quiet workout!
Key Features
Usage Instructions
