Treadmill Doctor Walking Belt for the LifeFitness 9100 Treadmill
Built to last, this Life Fitness 9100 Treadmill Walking Belt is engineered with 2-ply polypropylene and a polyester backing for unmatched durability. Upgrade your LifeFitness 9100 with this easy-to-install, high-quality Treadmill Doctor walking belt and get your treadmill and yourself back in top form in no time.
Compatibility
Designed for a perfect fit, this replacement belt seamlessly integrates with your LifeFitness 9100 Treadmill. Always confirm your model number before purchase to ensure compatibility and optimal performance.
Working
A treadmill belt operates via a motor-driven system. The motor powers the rollers located beneath the running surface. These rollers assist the walking belt in rotating around the deck, simulating forward motion and enabling you to walk and run at different speeds.
Uses
  • Cardio Training - When you walk, jog and run on the walking belt, it raises your heart rate for an extended period of time and keeps you in peak health.
  • Weight Management - Getting your steps in on a treadmill belt helps burn calories and fat and manage weight effectively for a healthy body and fitness.
  • Frayed Edges - Significant wear and tear along the edges of the belt could mean that your walking belt is worn out, not functioning optimally and needs replacement.
  • Increased Friction - If the walking belt has difficulty maintaining the speed you enter in the console, it could be due to a worn-out belt.
  • Noisy Operation - Loud squeaking and squealing sounds when the belt moves indicate belt slippage or wear.
Replace your worn-out Life Fitness 9100 walking belt from Treadmill Doctor TODAY!
Weight
8.0Lbs
Model
9100
Type
MPN
N/A
Activity
Walking/Jogging/Running
LifeFitness
Lifetime
Lifetime
Compatibility
Working
Uses
Product Specifications
Weight
8.0Lbs
Model
9100
Type
MPN
N/A
Activity
LifeFitness
