Image 60 GTS Treadmill Walking Belt Model Number IMTL59610 Part Number 413810
This is a premium-quality replacement belt built for the durability, longevity and performance of Image 60 GTS Treadmill. It is engineered with a multi-ply construction in industrial-grade polypropylene and polyester to provide a smooth and consistent running experience, even during your most intense workouts.
Compatibility
This walking belt is exclusively designed for the Image 60 GTS Treadmill Model number IMTL59610. Verify your specific treadmill model before purchasing.
Working
The treadmill motor spins the rollers under the deck, driving the belt to move back-to-front around the deck. This movement simulates walking or running on the equipment.
Uses
- High-Intensity Interval Training - You can adjust speed, incline, and decline, as well as have intense interval training by running on the treadmill belt.
- Better Physical Health - Walking on the treadmill improves endurance and overall physical health.
Problems That Lead to the Belt Replacement
- Cracking - The belt material develops cracks, especially in high friction areas and its performance is compromised.
- Lack of Lubrication - Neglecting regular lubrication significantly shortens the lifespan of the treadmill belt.
- Uneven Running Surface - The belt’s surface shows uneven wear or damage to the belt material.
Get a new Image 60 GTS Walking Belt for energizing workouts. Order your replacement belt from Treadmill Doctor Today!
Lifetime
Lifetime
Compatibility
Working
Uses
