Image 10.6Q Treadmill Walking Belt Model Numbers 297573, Sears Model 831297573
This is an Image 10.6Q Treadmill replacement belt designed for peak performance. Its two-ply construction in premium materials such as polypropylene and polyester offers enhanced grip and a comfortable workout experience. Upgrade your worn-out Image 10.6Q treadmill walking belt with a new one.
Compatibility
This walking belt is compatible with Image 10.6Q Treadmill with Model Number 297573 Sears Model 831297573. Check the compatibility of your specific model before placing an order.
Working
The mechanism of the treadmill belt simulates the feeling of outdoor movement while staying comfortably indoors. The treadmill belt moves around the deck, powered by the motors and rollers, which makes its circular motion at a consistent speed possible.
Uses
- Strength & Fitness- When you run on the walking belt, you build lower body strength and improve your core stability.
- Rehabilitation - You can walk or run on the treadmill belt with support, which helps in recovery from injuries and improves mobility.
Problems That Lead to the Belt Replacement
- Fraying Edges - The edges of the belt fray or tear due to constant friction and use, leading to a worn-out belt.
- Impact Stress - Friction, especially from heavier users or intense workouts, can cause cracking in the belt material.
- Improper Belt Tension - When belt tension is high, it causes excessive belt friction and damage.
Upgrade your worn-out Image 10.6Q Treadmill Belt with a brand-new replacement belt from Treadmill Doctor.
Lifetime
Lifetime
Compatibility
Working
Uses
