Horizon 7.0AT Treadmill Walking Belt Part Number 1000457653 For Model Number TM704 | TM1002
This is a Treadmill Doctor Replacment Walking Belt for a Horizon 7.0AT Treadmill Model Number TM704 | TM1002. When it comes to replacement walking belts Treadmill Doctor has been a leader in the fitness industry. Our walking belts are made from quality polypropylene materials, 2 ply construction with the backing made of polyester blended material. A warranty for our walking belts is offered depending on your setting you may want to opt for the Lifetime warranty when in a residential setting and the 1-year warranty in a commercial setting.
Compatibility
This replacement belt is compatible with the Horizon Fitness 7.0 AT treadmill only. It is not compatible with other treadmill models.
Working
The belt is an essential component of the treadmill. When worn or damaged, it can cause the treadmill to operate improperly. Horizon treadmill belt replacement will help restore it to its original performance.
Uses
This replacement belt replaces a worn or damaged belt on a Horizon 7.0 AT treadmill.
Problems that lead to the replacement of the belt
Several problems can lead to the treadmill repair or replacement of the belt. These include:
  • Wear and tear: The belt will experience wear and tear over time. This is especially true if the treadmill is used frequently.
  • Misalignment: If the belt is misaligned, it can cause excessive wear and tear.
  • Damage: The belt can be damaged if it comes into contact with a foreign object.
If you are experiencing any of these problems, it is time to replace the belt.
Weight
‎8.0 Lbs
Dimensions
N/A
Model
7.0AT
Type
MPN
1000457653
Activity
Running/Jogging/Walking
Horizon
We have two warranty periods for 1 year or a lifetime.
Walk Belt Warranty 1 YEAR - $129.99
RESIDENTIAL USE:
This product comes with Treadmill Doctor's leading 1-year warranty against any defects in materials or workmanship.
REQUIREMENTS FOR VALID WARRANTY: To maintain the warranty, the underside of the walking belt must be lubricated once every year using World Famous Lube.
COMMERCIAL USE:
The walking belt has a 30-day warranty for commercial applications.
Walk Belt Warranty LIFETIME - $139.99
RESIDENTIAL USE:
This product comes with Treadmill Doctor's industry-leading lifetime warranty against any defect in materials or workmanship.
REQUIREMENTS FOR VALID WARRANTY: Lubricate the underside of the walking belt once every year with World Famous Lube.
COMMERCIAL USE:
This product comes with a 1-year warrant for commercial applications.
REQUIREMENTS FOR VALID WARRANTY: Lubricate the underside of the walking belt once every three (3) months with World Famous Lube.
Lifetime
Walk Belt Warranty LIFETIME - $129.99 Read More Walk Belt Warranty 1 YEAR - $119.99 Read More
Lifetime
Compatibility
Working
Uses
About This Item
Weight
‎8.0 Lbs
Dimensions
N/A
Model
7.0AT
Type
MPN
1000457653
Activity
Horizon
Warranty Details
RESIDENTIAL USE:
COMMERCIAL USE:
RESIDENTIAL USE:
COMMERCIAL USE:
