ENGINEER MANUAL FOR AFTER SALE SERVICE
PRODUCT TREADMILL
MODEL (675i)
INFORMATION GUIDE
1. Information For Components & System
1.1. System Wiring Diagram
Back to Top
1.2. Motor Driver
J1 console wire-7 PINs
1 2 3 4 5 6 7
RPM DRIVE EN MOTOR EN SLOW FAST GND 12V
J2 console wire-5 PINs
1 2 3 4 5
VCC ADC GND UP DOWN
J3 speed sensor
1 2
GND RPM
J4 incline motor VR
1 2 3
VCC ADC GND
J6 AC AC Power input
1 2
ACL ACN
J7 DC Power output
1 2
M+ M-
J8 incline motor output
1 2 3 4 5
COM X UP X DOWN
LED pilot lamp
D1 Error D Console Power
D2 Speed Increase/ Decrease D9 Incline UP/Down
D7 DC Output Power
Back to Top
1.3. Console PCB
I/O Console wire
I/O Console wire
PIN 1 2 3 4 5 6 7 8 9 10 11 12
Define +5V ADC GND Down Up RPM +5V Motor EN Slow Fast GND +12V
I/O Console wire
PIN
Define
1
+5V
2
ADC
3
GND
4
Down
5
Up
6
RPM
7
+5V
8
Motor EN
9
Slow
10
Fast
11
GND
12
+12V
CP (ICP For program update
PIN 1 2 3 4
Define ICE_SCL Vcc(+5V) ICE_SDA GND
PIN
Define
1
ICE_SCL
2
Vcc(+5V)
3
ICE_SDA
4
GND
J3 Blue Tooth (BT)
P1 Vss Ground P4 UART-RxD-IN
P2 DC power supply P5 UART-CTS (not use)
P3 UART-TxD-OUT P6 UART-RTS (not use)
J3 Blue Tooth (BT)
P
Description
P1
Vss Ground
P2
DC power supply
P3
UART-TxD-OUT
P4
UART-RxD-IN
P5
UART-CTS (not use)
P6
UART-RTS (not use)
J4 DC12V
P1 12V P2 GND
J4 DC12V
P
Description
P1
12V
P2
GND
J6 iHP PCB (USB)
P1 UART-TXD P4 N.A
P2 UART-RXD P5 Vcc
P3 N.A P6 GND
J6 iHP PCB (USB)
P
Description
P1
UART-TXD
P2
UART-RXD
P3
N.A
P4
N.A
P5
Vcc
P6
GND
J7 Hand Pulse
P1 VCC P3 Output
P2 GND P4 12V
J7 Hand Pulse
P
Description
P1
VCC
P2
GND
P3
Output
P4
12V
J9 Wireless HR receiver
P1 Output P3 GND
P2 Vcc
P
Description
P1
Output
P2
Vcc
P3
GND
J10 SAFE KEY
P1 Driver EN P2 VCC
J10 SAFE KEY
P
Description
P1
Driver EN
P2
VCC
J14 PWM 12V power(fan)
P1 PWM 0~12V P2 GND
P
Description
P1
PWM 0~12V
P2
GND
KEY 1 Membrane
Pin\pin(com) 1 2 3 4 5
6 x x SPD + Q-SPD 4 X
7 x x SPD - Q-SPD 6 X
8 x x STOP Q-SPD 8 X
9 x x Blue Tooth Q-SPD 10 X
10 x x FAN x X
KEY 1 Membrane
Number
Description
1
x
2
x
3
SPD +
4
Q-SPD 4
5
x
6
x
7
x
8
x
9
x
10
x
J17 Handle Button - Speed (KEY 3)
P1 SPD - P3 COM
P2 INC +
P
Description
P1
SPD -
P2
SPD +
P3
COM
J18 Handle Button - Incline (KEY 4)
P1 INC - P3 COM
P2 INC +
P
Description
P1
INC -
P2
INC +
J19 Membrane (KEY 2)
Pin\pin(com) 1 2
3 INC + Q-INC 2
4 INC - Q-INC 4
5 START Q-INC 6
6 ENTER Q-INC 8
7 SELECT x
No.
Pin\pin(com)
1
INC +
2
Q-INC 2
3
INC +
4
INC -
5
START
6
ENTER
7
Q-INC 8
Back to Top
2. Error Signal Check Steps And Solutions
2.1.SPEED ERROR
Can not receive signal from speed sensor over 6 seconds while workout, all windows display will off, all output will stop, and show SPEED ERROR.
If this is a all new product that just finished assemble, there are more possibly in assemble problems, maybe connect wire not well or wire damaged while assemble.
Determine & Solution
Back to Top
2.2. E6
The incline AD parameter did not change over 7 seconds while operating the incline, incline function can not be use but other functions are normal to use.
Before install a new incline motor or VR, have to sure the incline motor or VR in the incline level 0 condition.
Back to Top
2.3. E7
Incline motor AD parameter out of the range. under 15 / over 120 .
Back to Top
3. Other Information
3.1. No Any Display On Console(No Power)
Back to Top
3.2. Key Lose Function
Back to Top
3.3. Real Speed Do Not To Fit In With Display Speed
Back to Top
4. Engineering Mode
4.1. Engineering Mode ONE Basic Settings
In idle mode, press and hold STOP then press Program Select to enter the mode.
4.1.1. Software information Message window show software version & modification date, press Enter to next setting.
4.1.2.Unit setting Message window show SET UNIT = KM , press FAST or SLOW can change to SET UNIT = EN , press Enter to next setting.
4.1.3.Perpetual calendar Select ON can edit the perpetual calendar.
4.1.4.Total used distance Message window show TOTAL DIST = , incline window show 000~999 km/mil, speed window will carry 1 if over 1000 km/mil, press Enter to next setting.
4.1.5.Total used time Message window show TOTAL TIME = , incline window show 000~999 hour, speed window will carry 1 if over 1000 hours, press Enter back to idle.
Back to Top
4.2. Engineering Mode TWO Test Mode
In idle mode, press and hold STOP then press Start to enter the mode.
4.2.1.Display test 1 Press STOP to next mode.
4.2.2.Display test 2 Press STOP to next mode.
4.2.3.Display test 3 Press STOP to next mode.
4.2.4.KEY test Dot-matrix window show KEY , each key has their own parameter show as below, press STOP to next mode.
Key Parameter Key Parameter
INCLINE UP 100 SPEED FAST 120
INCLINE DOWN 101 SPEED SLOW 121
START 102 BLUE TOOTH 123
ENTER 103 FAN 124
PROGRAM SELECT 104 SPEED 4 130
INCLINE 2 110 SPEED 6 131
INCLINE 4 111 SPEED 8 132
INCLINE 6 112 SPEED 10 133
INCLINE 8 113
4.2.5.IO test mode Press START can trip the motor control relay, press FAST or SLOW can control the motor manual, press incline UP or DOWN can drive incline motor manually, time window show incline motor AD parameter 0~255, speed window show real-time speed that feedback from speed sensor, press STOP to display test 1 or press and hold STOP then press START back to idle.
Back to Top
4.3. Engineering Mode THREE Data default(Erase)
4.3.1.Erase the Custom settings In idle mode, press and hold STOP then press Enter , Custom settings will erase to default value.
4.3.2.Erase the total used time & distance In engineering mode ONE, press and hold STOP then press Enter , total used time & distance will erase and Custom settings will erase to default value.
Back to Top
4.4. Engineering Mode FOUR iHP Perpetual calendar edit
Press any one of the speed express key while in the IDLE mode, message window show iHP internal date and time, press Enter back to idle or press and hold any one of the speed express key to edit the perpetual calendar.
4.4.1.Set Year Message window show SET YEAR = XX (XX 2011= 11), press FAST or DOWN to set, press Enter to next setting.
4.4.2.Set Month Message window show SET MONTH = XX (XX 1~12) , press FAST or DOWN to set, press Enter to next setting.
4.4.3.Set Date Message window show SET DATE = XX (XX 1~31) , press FAST or DOWN to set, press Enter to next setting.
4.4.4.Set Hour Message window show SET HOUR = XX , press FAST or DOWN to set, press Enter to next setting.
4.4.5.Set Minute Message window show SET MINUTE = XX, press FAST or DOWN to set, press Enter back to idle.
Back to Top
5. Program Update
5.1. Install Software from PC Site
5.1.1.Un-zip the zipped file Programmer v5.41 to (1) PC-site AP (2) PC-site Driver, entry the (1) PC-site AP document then execute and install the Setup.
5.1.2.Entry the (2) PC-site Driver document, cursor on file 0E6A030D_8051ISPICP_v3.00 then click mouse right side and select Install ( I ).
Back to Top
5.2. Programmer Update
5.2.1.Connect the programmer to PC USB port, the LED2 & LED3 on programmer will be light up.
5.2.2.Execute the programmer update PC site software.
5.2.3.Settings:
5.2.3.1. Programmer Type ICP
5.2.3.2. MCU Part No MPC82G516
5.2.3.3. Programming Area Whole-chip
5.2.3.4. ISP-memory 0xFC00~0xFFFF(1KB)
5.2.3.5. Select HWBS / LOCK / OSCDN
5.2.4.Load burning code and update programmer click Load File Select and open the burning code click Update Programmer update ok
5.2.5.Programmer update success, pull out the programmer from PC.
Back to Top
5.3. Program Update(switch ON the power input, console must be have power)
5.3.1.Open the small cover where on the back of console set->connect the programmer to console update port->press update button where on the programmer->programmer LED1 off after flash -> done
Back to Top
