I have an E33 error code
Includes Keys, Ironman, Alliance, Milestone, Encore, HealthTrainer, some Smooth models, some CardioZone models, Galyans, and several other brands.
Meaning of code:
It means the walking belt is traveling faster than the set speed on the console.
Step 1
First try calibrating the machine with the calibration help topic.
Step 2
Adjust the "comp" adjustment pot on the controller and retry calibration.
Step 3
Make sure the S F/B LED on the controller is flashing when the fan is moving inside the speed sensor. If not, check the speed sensor and the motor fan. Clean the sensor lens with a Q-tip and rubbing alcohol. If it still doesn't flash, check the motor fan "fins" and if they are OK, replace the speed sensor.
Step 4
Check to see if the "fins" on the fan are broken are missing. A broken fan can cause a bad reading. If this is the case, replace the fan.
Step 5
If overspeed is still occuring and you don't have a resolution with calibrating or the sensor, replacement of the Motor Controller or Console may be necessary.
Step 6
Check the wiring harness from the controller to the console for any evidence of a pinched, crimped, or loose wire.
