NordicTrack EXP 14I Treadmill Walking Belt Part Number 426497 For Model Number NTL184220
Revamp your treadmill with a new replacement belt crafted for longevity and strong durability to withstand rigorous workouts. It is built to deliver excellent performance with quality polypropylene materials and 2-ply construction employed in its development with backing made of polyester-blended material.
Compatibility
This replacement belt is specifically designed for the NordicTrack EXP 14i model number NTL184220. When purchasing, ensure your treadmill model number is compatible with the walking belt to make the installation process effortless and hassle-free.
Working
A walking belt is an essential component in the functioning of a treadmill. It is the surface area powered by the electric motor that rotates around the deck and enables you to walk, jog, run and perform mobility exercises while staying in one place.
Uses
The treadmill walking belt is primarily used for:
  • Cardio Training: A walking belt provides a stable running surface for cardio workouts on which you can get your heart pumping fast and enhance your heart health.
  • Weight Loss: Regular exercise on a treadmill burns calories and helps in weight management. Rehabilitation: A treadmill walking belt provides mobility to individuals in recovery and is useful in physical therapy.
  • Convenience: You can work out indoors and sustain an active lifestyle, irrespective of the weather conditions outside.
  • Excessive Friction: With regular use, the walking belt can wear down due to friction over time.
  • Cracks or Splits: Walking belts when exposed to heat or moisture can develop cracks or splits on them. This deterioration in the walking belt can result in needing a replacement belt.
  • Slipping: From constant use, the walking belt can stretch or become misaligned over time causing the belt to slip while walking. Replace it as soon as this happens.
  • Improper maintenance: The walking belt requires lubrication and cleaning at regular intervals. If ill-maintained, it will wear prematurely and need to be replaced.
  • Exceeding Weight Limit: Using a treadmill with excessive weight can lead to more friction with the walking belt and more wear and tear.
A worn-out walking belt should be replaced for a seamless workout session. Get a replacement belt from Treadmill Doctor for NordicTrack EXP 14i for a worry-free workout.
Weight
8.0 Lbs
Model
EXP 14i NTL184220
Type
MPN
426497
Activity
Running/Jogging/Walking
NordicTrack
Lifetime
Lifetime
Compatibility
Working
Uses
About This Item
Weight
8.0 Lbs
Model
EXP 14i NTL184220
Type
MPN
426497
Activity
NordicTrack
