Treadmill Doctor - The Most Trusted Name in Fitness Equipment background
My Account login register logout
Toll Free 888-362-1105
cart items in cart 0  |  total amount $0.00  |  View Cart
Treadmill Reviews Elliptical Reviews Our Story Products & Services Security & FAQs Contact Us
Treadmills - Ellipticals Reviewed
Treadmill Reviews
Treadmill "Best Buy"
Elliptical Reviews
Elliptical "Best Buy"
Treadmill Doctor Blog
Products & Services
Treadmill Belts
Treadmill Decks
Treadmill Motors
Motor Control Boards
Power Boards
Lubricant & Cleaners
Safety Keys
Motor Drive Belts
Maintenance & Care
Endcaps
Incline Motors
Electrical Parts
Rollers
Consoles
Treadmill Mats
Accessories
Doc´s Parts Repair Service
Nordic Track Ski Parts
Treadmill Doctor Service Locations
Troubleshooting
Find a Dealer
Find Local Service
Ask the Doc
Treadmill Doctor Info
Our Story
Contact Us
FAQs
E-mail Login
Terms of Service
Merchant Policy
Privacy Policy
Sitemap
Roller Sleeve Problems
On many treadmills, the factory originally made the drive roller with a traction sleeve to help grip the belt. This allows the belt to operate at a lower tension and subsequently, a lower amp draw which will prolong electronics and/or motor life as well as belt life. If you have a sleeve on your drive roller, do not remove it unless you are going to replace the sleeve.
If the sleeve is moving off to one side, which is a common problem on some treadmill, there are a few things you can try:
1) Trim the sleeve so it will be centered on the belt. A sleeve that is not centered will cause your belt to move to one side, will offload the force on the belt seam causing it to track unevenly and wear unevenly, and can ruin your walking belt. This will cause you to make regular adjustments to it and eventually you will need to replace the sleeve or the roller.
2) Replace the roller. The sleeve is either put on with an air compressor or by a heat machine so even if you could get the sleeve (which you cannot through the factories) most people would have no way to put it on.
3) The final option is to replace the sleeve cover. We finally have sleeve kits in stock after a long wait. You will need a torch or a heat gun to shrink the sleeve to the roller. The sleeve kit is $29.95 and includes everything you will need except the heat device. If you prefer that we do the work, we charge $49.95 for the parts and labor to do this and the roller has to be shipped to our Memphis warehouse.
_______________________________________________________
Copyright © 2003 by TreadmillDoctor.com, Inc.
All illustrations, photographs, and scanned images, and text are the property of TreadmillDoctor.com, Inc. and may not be reused, retransmitted, copied, given, sold, or bartered to any third party. The recipient of this property is authorized to use it only in the manner expressly indicated by a staff member of TreadmillDoctor.com, Inc. All rights reserved.
Click Here for the PDF version of this document
