Our new and improved troubleshooting section was carefully constructed to put the power to repair your machine in your hands. As you can tell, we have put a great deal of time, effort and detail into making the process easy to understand for a wide variety of individuals. All of this can save you the cost of a service call which is approaching $150 in many markets and in many cases, we can save you the cost of parts since many parts are sold from factories unnecessarily (many parts cost over $100 alone). That being said, we hope that you find this troubleshooting area helpful. Should you find that our troubleshooting tips help you out, please donate to keep this info on the web. We have been informed by a number of our users that they feel that donating 10% of the cost of what they feel our troubleshooting tips saved them seems appropriate. However any donation is welcomed and appreciated. As donations come in we will continue to add to this area of the site in an effort to make your ownership of fitness equipment an enjoyable one. One of the first areas we would like to begin updating is the addition of video posts as a tool to assist our user community. If this info helps you, please click on the donate button and donate to help us expand and maintain our troubleshooting help. Please note that donations, while appreciated, are NOT tax deductable.
The PDF forms on this page require the Acrobat Reader.
Click on the Adobe image to download Acrobat Reader.
Installing An Icon Fitness Treadmill Belt- No Exposed Front Roller Bolts
You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Before unfolding the treadmill, disconnect the lift shock from the ball joint. Most have a small retainer clip that can be pulled with a small flathead screwdriver and then the shock can be removed from the ball stud.
Step #2- Unfold the treadmill and then remove the three wiring connectors for the incline motor and then one of the incline motor mounting bolts.
Step #3- There are two shoulder bolts that hold the entire motor tray in place. These are at the back of the motor area and must be removed to gain access to the front roller bolts. Remove the two shoulder bolts and then you can pull the motor tray slightly forward or backward to gain access to the roller bolts.
Step #4- Follow the replacement instructions included with the walking belt.
Step #5- Reverse the process of step one, two, and three to reassemble the treadmill.
_______________________________________________________
Copyright © 2008 by TreadmillDoctor.com, Inc.
All illustrations, photographs, and scanned images, and text are the property of TreadmillDoctor.com, Inc. and may not be reused, retransmitted, copied, given, sold, or bartered to any third party. The recipient of this property is authorized to use it only in the manner expressly indicated by a staff member of TreadmillDoctor.com, Inc. All rights reserved.
Click Here for the PDF version of this document
